OT Lower a 2 1/2 Ton Army Trailer?????
Mel in SW Iowa
12-12-2007 16:15:18
I have a 2 1/2 Ton Army Cargo Trailer that I would
like to lower at least 12", put a wagon hoist on,
and pull with either a tractor or a 1T pickup to load and haul fill dirt, haul brush, etc. This will be used mostly off-road, but ocassionally taken on roads.
If I relocate the axle from under the leaf springs to over the springs, it will almost become a solid axle. I could exchange the 9.00 X 20 tires for a smaller tire, maybe a 7.00 X
20. Both of these changes might do it, but I hate
to lose the suspension if I don't have to.
Cutting the axle and making a drop axle out of it
might be a better if more difficult solution. (These are split rims. I have always used a piece of channel to clamp rims and axles into to
insure fabricated axle alignment.) Has anyone done or had an inspiration about how
to best do this?
I would like to retain the parking brakes and maybe the service brakes.
Thanks,
Mel
Bill(Wis)
12-13-2007 21:24:54
 Re: OT Lower a 2 1/2 Ton Army Trailer????? in reply to Mel in SW Iowa, 12-12-2007 16:15:18
Smaller diameter wheels. But it wouldn't dump good if wheels were too small (if I'm envisioning this correctly).
johns48jdb
12-13-2007 05:34:28
sell the trailer and use that money and the cost of a wagon hoist and buy you a used dump truck. hauling dirt and rocks might be a bit much on a wagon hoist to lift, depending on how much you haul at once, of course. if your going to haul a load you might as well haul all you can in one trip the way the price of gas is.
Dale B
12-12-2007 18:57:06
I'm gonna guess you have 5 or 6 hole Budd wheels on the trailer ? You could try 8.25 or 900 X15 lowbed trailer tires as used on heavy equip. trailers. there are 5 & 6 hole wheels that will bolt to your hubs . Check brake drum clearance..... ..
