275 baler flywheel play
spitz
12-10-2007 13:37:01
Just noticed as I put a shear bolt in the flywheel re-baling some loose hay. The flywheel "wiggles" up and down a little. Does this have a bushing or bearing that is worn or is this "wobble" supposed to be there to help align the shear bolts?
chuck bergstrom
12-10-2007 15:02:25
 Re: 275 baler flywheel play in reply to spitz, 12-10-2007 13:37:01
Spitz, There is a bushing in the flywheel. Same
bushing fits most NH balers. Replace it, you'll
use fewer shear pins. p/n 37731 ?? from memory
but memory is fading. Chuck
rrlund
12-10-2007 16:00:25
 Re: 275 baler flywheel play in reply to chuck bergstrom, 12-10-2007 15:02:25
Just be sure to eat your Wheaties before you try to take the flywheel of of there!
