Allis-Chalmers Field Cultivators...1200 and 1300 Series
Blue Horse
12-07-2007 06:11:57
Can someone inform me if parts (shanks, etc.) are interchangeable between the 1200 and 1300 series field cultivators? From what I have read, it appears that the 1200 series was available up to 21.5 feet, whereas the hyd-fold 1300 models started at about 22.5 feet. Looking at the two, it also appears the 1300 may be considerably heavier, but maybe it just looks that way. Also, can someone give me a tip on the best way to secure the rubber blocks when installing a shank on the bar? Hose clamp?
jimont
12-07-2007 10:09:27
 Re: Allis-Chalmers Field Cultivators...1200 and 1300 Series in reply to Blue Horse, 12-07-2007 06:11:57
I think you'll find the only difference between models is that the 1300's had heavier frames as the higher hp tractors were tearing the 1200's apart. Shanks should be the same for both. One of the best cultivators going for our heavy clay around here. I believe they were advertised as the "silent weed killers". Never had a problem with the rubber mounts.
