Plough question
John-Paul (Finl
04-10-2000 01:47:02
Hi,
In general, is it possible to convert a 3-furrow plough to a 2-furrow one by unbolting the end set of blades?
Thanks,
J-P
Phillip Squires
03-07-2001 15:22:03
 Re: Plough question in reply to John-Paul (Finland), 04-10-2000 01:47:02
I was wondering if you could send me some pictures of a Two Furrow Plough for a school assignment
TomH
04-10-2000 17:02:12
If there is a way, try to move the mounting so you are pulling from the middle of the two bottoms that are left. Center of draft should be the center of the tractor.
ted
04-11-2000 13:02:23
 Re: Re: Plough question in reply to TomH, 04-10-2000 17:02:12
Plows don't have to be pulled from the center. Each molboard has a landslide that centers its own draft. This is how you can have 6, 7 + bottoms on a plow and still run in furrow.
Tim W
04-10-2000 03:11:43
If the most rear bottom has a long landside, that should be moved up so the bottom with the longer landside is the last bottom.
Wayne
04-10-2000 02:57:21
Sometimes this can be done on semimounted plows. The back beam is removed and the tail wheel is moved up to replace it. If it can be done it is just a matter of removing bolts and replacing them.
John-Paul - thanks for the help (no message)
04-11-2000 06:01:04
 Re: Re: Plough question in reply to Wayne, 04-10-2000 02:57:21
