A/C plow
Rickey h
11-23-2007 18:36:52
Will shares and or shims, moldboards from a 53 model plow fit a 80 model? or will anything thing else work? Thanks Rickey
Gerald J.
11-23-2007 19:13:03
 Re: A/C plow in reply to Rickey h, 11-23-2007 18:36:52
Probably if you also move the frog, but only if the two bolts that hold the frog (and probably the landside) fit the holes on the later plow frame. AC used many different bottoms on their plows. Nearly all bottoms fit all plows, so long as you move the whole bottom including the frog.
Gerald J.
