600.16 tires what size today?
pa dave
11-23-2007 11:54:32
we have a graindrill that has 600.16 on it they need replaced, what size would that be in todays size? need same height so acreage meeter seed drill will work correct. do they (tire companys) have a converson chart, or does anyone have a way to convert old sizes to new sizes thanks
hdg6tom
11-24-2007 06:47:48
 Re: 600.16 tires what size today? in reply to pa dave, 11-23-2007 11:54:32
If I were still in the tire business and you came into my shop 600x16 6 ply tires would cost you 40.04 each, put on the rim.
Don-Wi
11-23-2007 23:10:46
Are they old car/truck tires or implement tires? They have slightly different measurements from each other, but I'm not sure which one is smaller. If it's an implement tire, jsut go with a new one. Still common enough that our local tire guys stock it.
Donovan from Wisconsin
msb
11-23-2007 17:16:18
Link Take a look or better yet, order a catalog.
RickB
11-23-2007 16:27:05
Go to an Ag tire manufacturer's website and look up the loaded radius or rolling circumference for the 6.00-16 implement tire that is still available today in several brands. Then go to an automobile tire manufacturer's website and match the info. Or just buy the 6.00-16's and be done with it.
TomTex
11-23-2007 15:47:09
The manual for your drill will give the exact height of the tire/wheel. All tire stores have charts that give you height of all tire sizes. Simple, cspy given measurement out of Operator Manual, take to tire store. Tom
MIKE FRENCH
11-23-2007 15:01:24
600-16s are still availble, if want the next size is 650-16s, just got to look.
(sonny)
11-23-2007 13:41:26
tiretown.com
sonny
tractormiallis
11-23-2007 12:42:27
Have the same problem. I need new tires desperately, mine are all rotted, sidewalls out, but would like to find used tires or something, hate to spend the $$ for brand new, for a non road use implement.
