John deere moddel 813 plows
dave
04-09-2000 13:29:38
I would like to know if there is a way to put rubber tires on my set of plows. Right now they are wire spoked rims with metal wheels. Thank you for any information.
Bob
04-09-2000 19:22:01
 Re: john deere moddel 813 plows in reply to dave, 04-09-2000 13:29:38
Dave, If your plow is really a model 813 it is a mounted(3 point hitch) plow and you probably don't need rubber tires. If you are refering to the number stamped into the beam, look closer it is probably a 613 which is just the beam number but means it is a two bottom number 52 plow. This very likely could have steel wheels. An optional rubber tire wheel was available but you may have trouble finding a good set. The option WHICH I DON'T ENCOURAGE is to cut off the spokes and weld on a rim that will take a tire that is readily available. Before you do that, I have seen guys fit tube liners from truck tires tightly over the steel wheel which might help if your hard surface travel is minimal. Let me know if I misunderstood the question. hope this helps. Bob
drawbar
04-11-2000 14:42:38
 Re: Re: john deere moddel 813 plows in reply to Bob, 04-09-2000 19:22:01
good advice about trying to put rubber treads on the steel tires. Dave, if you plan on pulling it on road(s) then i understand why you want pneumatic tires on a plow....but if you are using for field work only...then why would you WANT pneumatic tires over steel tires?? There's lots of more modern plows around for $50 - $500. I believe we need to give this old equipment a break. Repair it (properly), Yes. Use it in the field as intended, Yes. Cut'n weld, paint pink & put flower pot on, modify to modern config, No. Give that 'ole boy a break. and that's my opinion worth $.02
Destiny
09-01-2002 15:28:56
 Re: Re: Re: john deere moddel 813 plows in reply to drawbar, 04-11-2000 14:42:38
how do i become a moddle i wont to become please write me back
