John Deere Model 43 Corn Sheller
Fustrated Farme
11-20-2007 20:14:38
Need general info for Model 43 Corn Sheller.
All is appreciated
Thanks
Loren
Fustrated Farmer
11-26-2007 13:01:54
 Re: John Deere Model 43 Corn Sheller in reply to Fustrated Farmer, 11-20-2007 20:14:38
Your opinion on whether or not using on would be worth it. It being $400 and The owner not using it since he bought it. I would be using it for a small operation. Your Thoughts
Thanks
Loren
Tom671
11-22-2007 04:40:13
Min HP is 22 PTO
Later
Tom671
Tom671
11-21-2007 04:25:14
Not sure what to tell you. I have one and it has been in the barn for over twenty years. I have a manual for it, so if you have any specific questions, ask away. Mine is a 3pt hitch model and weighs about 200 lbs without the chain auger. It is suppose to shell corn at at rate of 100 to 250 bushel per hour, but that was back in the late 1950s to early 70s before all this hybryd corn.
Later
Tom
Fustrated Farmer
11-21-2007 19:51:29
 Re: John Deere Model 43 Corn Sheller in reply to Tom671, 11-21-2007 04:25:14
What Is the Min. HP required?
How well did it work?
What would go wrong with them?
Thanks
Loren
jd-tom
11-23-2007 21:59:33
 Re: John Deere Model 43 Corn Sheller in reply to Fustrated Farmer, 11-21-2007 19:51:29
I have an original sales brochure for one and it says it requires 10 hp. I have one of these but have not used it for many years. I remember it does a good job if you can keep it pretty full. If the rubber paddles on the shelled corn thrower are worn out it will crack the corn pretty bad as it throws it into the wagon.
msb
11-21-2007 20:45:43
"What Is the Min. HP required?" That depends on how fast you can shovel.
