Buzz saws!
Sarge68
11-20-2007 14:57:14
Am looking for a website or a physical location in the Pacific NW where I can get a good used or fixer-upper 3 pt. hitch, PTO driven buzz saw. I'm clearing 40+ acres of junipers this year and figure this is the best way to go considering the terrain!! Thanks!!!
Spritzer
11-25-2007 13:05:37
 Re: Buzz saws! in reply to Sarge68, 11-20-2007 14:57:14
Don't know what quantity of wood you're planning to do, but 40 A. sounds like it justifies getting a buzz saw. A PTO-driven saw can cut wood 5 times faster than a chain saw, and with less muscle and back fatigue. Mine is mounted on a 2-wheeled frame. Pulley mounted on rear of shaft which drives the second shaft on which the blade is mounted.(Belt serves as a slip-clutch if needed) Blade is 31", table is tilt-type. Works slick! Can cut a 12" log in one whack.
johns48jdb
11-22-2007 08:35:03
what diameter are the things your trying to cut. i use to see advertisments for a 3 pt bush hog that had a rack built on top of the bush hog that pushed the trees over away from the operator and then the bush hog whacked them down. i don't know that i've ever seen a saw mounted on a tractor like that. my grandfather use to have a little one cylinder garden tractor with a saw blade mounted on the front of it. you could lay it down flat to cut a tree down and then twist it up straight to saw it up into fire wood or logs.
Sam#3
11-21-2007 16:45:41
Seriously,
I'm Wondering why you want a buzz saw because you're "clearing 40+ acres of junipers . . . " I haven't seen any one use a buzz saw since the developed the one man chainsaws. How do you intend to fell and trim the junipers?
