wagon plans
Robert Huntress
11-13-2007 20:45:06
Does anyone have a good set of prints for a homemade wagon gear? I've drawn out a partial set from pictures, but the steering system is a little vague. Are 1/2" tie rods with a length adjustment over the tongue pivot heavy enough? I am currently looking at building it with 66" axles measured inner hub plate to inner hub plate, to allow for a 96" width on the bed. Any input would be appreciated.
M Nut
11-15-2007 09:47:01
 Re: wagon plans in reply to Robert Huntress, 11-13-2007 20:45:06
Just a thought, do you want to build one as a project for fun, or simply need a wagon? Why not watch around and buy one?
I had a 6 ton Kaston running gear I repainted and put good tires on and put a new 8x16ft whiteoak bed on it. I had a heck of a time getting $500 for it. That was the 1st and last wagon I ever tried to sell and make a little money on. Didn't quite get my money back on expenses in the end.
Robert Huntress
11-15-2007 16:51:25
 Re: wagon plans in reply to M Nut, 11-15-2007 09:47:01
I willbe needing a hay wagon next season. However, I talked to a fellow in town who has a 30'x8' wagon that I'll probably get. It's a shame, since I have the perfect rear axle. Like you mentioned, though, I can't build one for as little as buying an old one and refitting it with a wooden deck. I will probably keep the I beams members, though. I would like to thank everyone who has posted. I searched the net this morning for those lincoln electric plans, also. Thank you guys.
paul
11-15-2007 19:52:21
 Re: wagon plans in reply to Robert Huntress, 11-15-2007 16:51:25
30 foot????? Was that a typo? I sure wouldn't want that! :)
--->Paul
Robert Huntress
11-15-2007 20:54:03
 Re: wagon plans in reply to paul, 11-15-2007 19:52:21
No typo, it's huge. It has a metal bed, which is going to need replacing.
poogie
11-14-2007 13:41:45
University of Missouri had some plans that some of the Vo-Ag faculty and a Vo-ag instructor at Troy, Missouri made. It is called the Troy wagon and the authors of the plans were Jesse clounts ,_____ _Parker, and _____ __ ___ Sorry do not remember all of the names. I have 3 of the wagons
Vapet
11-14-2007 12:34:14
Lincoln Electric had some good farm project books back in the 50's and 60's. Don't know about now but you might do some searching and find some.
KEH
11-14-2007 16:04:55
 Re: wagon plans in reply to Vapet, 11-14-2007 12:34:14
The Lincoln book had 2 types of wagon plans. One type involved using an old car chassis of the Model A Ford type. The steering linkage was reversed, as I recall. Expert opinion locally said this type wandered over the road at any speed and was hard to back up.
The second type was a 5th wheel type which was supposed to back up easily and could go down the road at normal speed in a straight line. The plans involved making two straight axles of large pipe. The front axle had a round disk of heavy flat steel with a connecting pin in the center going through a corresponding heavy disk which attached to the wagon frame. A hitch was attached to the front axle with pins. The wagon bed had to be high enough so the wheels could clear the frame as the axle turned.
KEH
edchainsaw
11-16-2007 20:07:30
 Re: wagon plans in reply to KEH, 11-14-2007 16:04:55
my gramdfather built a gear from a Model A back in the winter of 1936... he and a friend took a week working everyday on it.. ( I still have this gear--(I am not taking good care of it I am sorry for that) its very week the last time it was moved was sometime in 1978 or 9... it is in a shed... but I wouldn't waste time or money building one...
