Speakin' of Spray Cans...
Paul Fox
04-09-2000 03:26:20
I got to thinking about this whole painting thing, and checked on how much I spent painting my F14 with cans. It don't take long to figure out that I could have easily paid for some painting equipment and gotten a better job for less money.
So then, I got to thinking about why I didn't do that. I don't like wasting time or money any more than anyone else, so there must have been a reason. And sure enough, there was.
What with one thing and another, my time to work on my toys tends to come in small bites over a long period of time. As a result, I frequently need (want) to paint one or two little pieces at a time. What it comes down to is 5 minutes with a spray can, or an hour setting up, mixing, painting and cleaning up with a spray rig. No contest in my mind.
Of course, I COULD do my cleaning and prepping in those short work sessions, and save everything for one marathon painting session. But that would take organization, will power, planning and patience. Which, for me, would take all the fun out of it.
Of course, something like a trailer is necessarily one big project, and a sprayer would be the way to go. I withdraw my suggestion about cans.
Might have to try the organized approach one day when I grow up tho... :-)
Dick Davis
04-11-2000 04:32:39
 Re: Speakin' of Spray Cans... in reply to Paul Fox, 04-09-2000 03:26:20
Has anybody ever seen for sale pressure cans (about the size of a spray paint can) that you can pump up with your air compressor and then screw onto a cup that you fill with paint? I can't remember whether this system was used by Navy aircraft painters or I dreamed it up. The advantage is the pressure source is small/handy/reuseable/cheap over time with any color paint and allows small batch application and tiny clean up requirements.
george s.
04-12-2000 11:15:14
 Re: Re: Speakin' of Spray Cans... in reply to Dick Davis, 04-11-2000 04:32:39
Just saw one today in Northern Tools summer sale catalog, Item # 150247-F722 , $12.99.
charge with 50-90#, sprays paint, lube etc.
Let us know how it works if you get one.
Dan from PA
04-13-2000 21:00:26
 Re: Re: Re: Speakin' of Spray Cans... in reply to george s., 04-12-2000 11:15:14
I got one of these a few years back. Didn't work worth ****. The paint wouldn't atomize properly, no matter how I thinned it. I used as much pressure as the pop-off valve on it would allow. It even had a few different tips, none of which work properly.
Thin liquids worked a little better. I use it to dispense cutting fluid on my drill press.
Dick L
04-09-2000 10:02:52
Now don't get me wrong,I'm not recommending this. I'm a lazzy old buzzard and I only clean my HVLP paint gun when it stops working properly or I change colors. I have been painting Allis orange off and on for months and I have cleaned the gun about four times. When I get done spray painting I cup a thinner soaked rag over the nozzle and pull the trigger and blow back into the cup.
This wont work on paint with a hardener just oil based machinery paint. When I get ready to paint the next time I shake the paint real good, blow back through the gun with the rag and check the spray pattern on a board and start painting. Like I said I am not recommending this it is just what a lazzy old man does.
.Forgot to add.
04-09-2000 10:02:20
Paul: I forgot to say that a Dremel is a complete unit, compressor\motor, hobby type sprayed that can be used\stored in a small box. The small glass bottles baby food comes in can be used as the 'gun' and is great for real hard to get at places. I had a track-loader that I shot all the real hard to reach places with it. I feel its just about as handy & quick as a spraycan. h
big fred
04-09-2000 09:00:22
Paul, when I painted my little utility trailer, I got a can of blue (something or other, can't remember the manufacturer) paint, a couple disposable brushes and let the kids loose. I ended up with a paint job that has lasted about 10 years now out in our rainy climate. I also got a bunch of nice blue concrete deck blocks. The trailer was blocked up on them and the kids kinda went nuts. My total cost was about twelve bucks.
04-09-2000 09:39:03
 Re: Re: Speakin' of Spray Cans... in reply to big fred, 04-09-2000 09:00:22
For equipment I like a good old oil based enamel.
An old guy taught me this methood though.... Get a hot plate and put a cooking
pot on it big enough to hold a gallon paint can. Fill the pot with water and
let your paint float in it. Heat the water too about 100-110 degrees. Put
the paint on with a nice fine bristle brush. You would not believe the results
this gets. I could not believe it was possible with a brush until I tried it.
By having the paint almost hot all the brush strokes smooth right out and
you get a nice heavy coat that will last forever. I even saw a car done
that way.
Valvejob
04-10-2000 21:56:27
 Re: Re: Re: Speakin' of Spray Cans... in reply to ., 04-09-2000 09:39:03
Wow! neat idea, I have a few JD parts I was ready to brush paint. I will try the heated paint, I usually end up brushing small projects because I don't want overspray all over the shop. Thank you!
I agree
04-09-2000 06:27:32
Paul: Well said. I guess thats why it's cheaper to buy potatoes by the truck load rather than by the 5 lb bag only when you need some. It just never works out well buying too much at one time. I have a small Dremel paint sprayer that fits in a 15X15 inch box and has a half pint paint can, I pre mix a quart and fill from that to the half pint sprayer. The Dremel is quick and easy to clean and I get a better pattern than a regular spray can. Maybe a small Dremel sprayer would be half way method for you to consider? Always another choice? Best to you. harvey
Bob
04-09-2000 12:57:57
 Re: Re: Speakin' of Spray Cans... in reply to I agree, 04-09-2000 06:27:32
You guys are great, I just got a bunch of super ideas about paint and painting and now I don't feel so bad about always looking for the lazy way to do it! thanks Bob
john d
04-10-2000 10:22:12
 Re: Re: Re: Speakin' of Spray Cans... in reply to Bob, 04-09-2000 12:57:57
If there is a place with more accumulated knowledge (which people are willing to share) than there is on this site, I sure haven't found it!!
