Your belt dealer is crying all the way to the bank! I have a Caroni finish mower I just parked last year, after 20+ seasons of mowing 2+ acres a week. I replaced the deck once, one spindle and 2 bearings. I also bought ONE set of replacement belts. That's right, 1 set and the replacements are still on it and in great shape. Gates makes...or did...excellent belts. You've got something mechanical killing those belts. Either pulley alignment or you are tightening them too much....or both. Not enough tension will kill them too. Heat from friction breaks them down. make sure your pulleys are aligned....all the proper highth to one another and that there is the proper amount of tension applied. Are your spindle bearings good? Can you freely turn each spindle by hand...and the spindle spins with a flick of the wrist? If you have bad bearings and the spindles are dragging and/or the spindle shafts are wobbling, this will destroy the belts. I would start by cleaning all the debris from the deck, remove the belt guards and measure the highth of the pulleys....if all are level within 1/16", I'd say that is fine. They should actually be the same...but 1/16" isn't much. Take the belts off. Rotate each spindle by hand, feeling for roughness. They should spin smooth as glass. See if you get any side play in the spindle shafts, there should be NONE. See if you can get any horizontal movement of the spindles..they shouldn't move up and down either. Next,check and see if the spindle assemblies are straight and not canted on the deck. This could happen if you struck something a hard blow. If the spindles all check out OK, if you have an idler pulley or pulleys, make sure they run freely and apply proper tension if they use a spring like Woods brand mowers do. If you adjust tension by sliding the gear box, then make sure the belts show about 1/2" deflection at a point half way between the drive pulley and the outboard spindle pulley. Don't tighten them like banjo strings! If you do this and still destroy belts....sell the damn thing and buy another unit.
