JD plow
Dave in S MN
11-01-2007 05:58:17
hey guys-
I have a JD 44 plow I just bought this year and have used a little bit. I broke the point off of one of the shears(hit a rock) and now needs to be fixed. This is making me wonder if it wouldn't almost be easier(or possible) to get ahold of some newer style frogs to put on so I could go with newer throw away shears. Has anyone ever done this or would it even be possible?
KW Primmer
11-01-2007 15:27:48
 Re: JD plow in reply to Dave in S MN, 11-01-2007 05:58:17
I agree with what others have said especially concerning Mr. Coates. He is a class act, one of a kind. I'm in the process of switching a #44 from "old style" to "new style" bottoms - 14 inch HS. New style frogs bolt right up to the shank/standard. I've never checked on frogs but moldboards, shins, shares and landsides for 14 inch HS style bottoms are available from JD, pricey in some cases but available.
KW Primmer
11-01-2007 15:26:48
Budd
11-02-2007 04:55:54
 Re: JD plow in reply to KW Primmer, 11-01-2007 15:26:48
I bought two "complete" units from Doug for $100 each. That was everything from the standard down. I just unbolted my standard and bolted the new one to my plow. It only took me about 1/2 hour and I was ready to plow.
BUDD
Budd
11-01-2007 11:55:35
Give this guy a call he will help you with what you want to do or at least give you the info you need. Doug Coats 563-588-1058 He is in Dubuque Ia Heck of a nice guy to deal with. I bought two complete HS bottoms from him for my 44 plow.
BUDD
ET
11-01-2007 07:08:05
All of the HS and NU bottoms will bolt right on but not the metric one. If you are going to plow much and in rocky ground its the way to go.
Dave in S MN
11-01-2007 10:11:53
 Re: JD plow in reply to ET, 11-01-2007 07:08:05
Hope this doesn't sound too dumb but what is HS and NU?
ET
11-01-2007 11:39:04
 Re: JD plow in reply to Dave in S MN, 11-01-2007 10:11:53
HS is high speed, NU is new universal. Both have throw away points and shins.
