Syracuse chilld plow co. inc. NY
grabs
10-31-2007 15:16:47
I have a syracuse plow and cant find any info. it is a 16 in plow #1450 n f made by syracuse chilld plow co.inc.NY need info thanks
JK-NY
10-31-2007 18:37:48
 Re: Syracuse chilld plow co. inc. NY in reply to grabs, 10-31-2007 15:16:47
What you have is an early John Deere plow. John Deere owned the Syracuse Chilled Plow works . I believe it operated into the 1940's.
grabs pat
10-31-2007 19:12:45
 Re: Syracuse chilld plow co. inc. NY in reply to JK-NY, 10-31-2007 18:37:48
this plow does not have any JD marking no where could it have been made before JD bought them ,is there a call for them if so let me no its fore sale,this is not a walking plow it is a 16in plow
Bob Collins
11-01-2007 05:45:46
 Re: Syracuse chilld plow co. inc. NY in reply to grabs pat, 10-31-2007 19:12:45
1450 is a designation for a 16" right hand Syracuse plow Bottom. What you are telling us seems to indicate you have a tractor plow. John Deere bought Syracuse Plow works before they were making parts for tractor plows. If you could post a picture it would speed things up, but just a description with numbers would help. Things like wheels, beam(s) and hitch will point toward more info for you. For example I am GUESSING you have two steel wheels with spokes, a frame made of rectangular steel stock, and two levers for adjustment. Somewhere there should be more numbers, let us know.
pat grabs
11-01-2007 10:12:37
 Re: Syracuse chilld plow co. inc. NY in reply to Bob Collins, 11-01-2007 05:45:46
I just have the plow,on the back it has the name Syracuse Chilld plow co.inc.NY #1450 np casted on the back and there is casted strips that run from the front to the back the name is casted in with thes strips. I have had jd guys look at it and thay say thay have never seen one like it.and i have been all over the inter net and i have not seen any like it eather .ther si no john deer name no where on the plow,I am having pic. done
Bob Collins
11-01-2007 17:34:25
 Re: Syracuse chilld plow co. inc. NY in reply to pat grabs, 11-01-2007 10:12:37
When you say "I just have the plow" I take it you MEAN you just have the plow bottom. The term "plow" refers to the whole implement, that can be used with horse or tractor power. You apparently have just the bottom or maybe just the moldboard. Some cast Syracuse moldboards did indeed have cast on ribs or "stripes" and while less common now, they are still around and were made while under the ownership of John Deere. These moldboards will fit Syracuse bottom assemblies with the 1450 designation and were used on many different plow implements.
pat grabs
11-01-2007 21:22:38
 Re: Syracuse chilld plow co. inc. NY in reply to Bob Collins, 11-01-2007 17:34:25
I guess its the moldboard,its the part that the point bolts on to,i will have a pic in a few days. thanks
