KUHN 55s disc mower
TPIA
10-26-2007 17:59:04
there is a State DOT sale tomorrow that has 3 Kuhn 55s/155 disc mowers on it .My question is what are they worth ,One is in excellrnt cond other two just fair cond .Any thoughts apppreciated thanks TOM
RodInNS
10-26-2007 20:00:58
 Re: KUHN 55s disc mower in reply to TPIA, 10-26-2007 17:59:04
Not too much because you really have no way of knowing what you're buying. Knowing where they came from tells you that they were run hard...
Check all discs for play/bad bearings. Check the curtain, because if it's not complete you will need one and they aren't cheap. Look them over for leaks and signs of leaking and any other things regarding their general condition.
Those are only small mowers but I think they could be worth anything from 100 bucks to 1500 bucks if it's very nice. Don't think I'd want to pass a grand on most of them. They're just expensive to fix if there is problems.
Rod
TPIA
10-26-2007 20:12:23
 Re: KUHN 55s disc mower in reply to RodInNS, 10-26-2007 20:00:58
ROD Thanks for your info I will look at the things you mentioned as this type mower is new to me I want one to mow waterways so size is not a big factor Thanks again TOM
K.W. in Tx
10-26-2007 21:14:22
 Re: KUHN 55s disc mower in reply to TPIA, 10-26-2007 20:12:23
You should also check the housing with the pulley that runs the bar. They are usually wore behind the pulley so that the pulley is cock-eyed. That will cause the belts to jump off and aint easy to fix.
