Culti-packer
chris stephenso
10-24-2007 11:59:17
I need a 3 wheels for a Cultipacker
Make is a McCormick-Deering, soil pulverizer
The patent on it is 1.533.014, 1.705.294
Any ideas on where i can find this
BobHnwOh
10-24-2007 15:13:51
 Re: Culti-packer in reply to chris stephenson, 10-24-2007 11:59:17
Measure O.D.,I.D.,and width.
CENTAUR
10-24-2007 12:46:16
What kind of bearing is it and does it have a number on it? Is it wood or metal? CENTAUR
chris stephenson
10-24-2007 13:29:36
 Re: Culti-packer in reply to CENTAUR, 10-24-2007 12:46:16
not sure abount the # on the bearing, i can take a picture of it if that will help. it is metal
CENTAUR
10-24-2007 13:55:07
 Re: Culti-packer in reply to chris stephenson, 10-24-2007 13:29:36
I think I made a misstake as you asked for wheels not bearings.However if you have worn wooden bearings some one with a large enough lathe could make some out of a block of hardwood.It may be possible to reverse the worn top side to the bottom.I did this on a semi floating truck axle by turning the worn top of the timken race to the bottom and the noise went away.That was many a year ago. CENTAUR
CENTAUR
10-24-2007 14:16:15
 Re: Culti-packer in reply to CENTAUR, 10-24-2007 13:55:07
Those old wooden bearings were encapsulated inside of the castings.A picture would not help as I have never even seen or worked on one.I did take apart a MODEL 10A McCormick bearing to see how it was made and wearing as I had to see inside.I still do that but I do not make work like I used to.I think I am older then (OLD) is. CENTAUR
