hydraulic rake problems
pork
10-19-2007 18:31:19
weve got a new idea hydraulic power basket/bar rake. had it for 17 years and works great. you can slow your ground speed in heavy silage hay and the rake speed stays the same. heres the problem: we run it with a 674 ih which were selling because we dont need it any more(dont need 2 hay loaders and the other is a bobcat, which we must keep.) apparently , the 674 runs its oil through the cooler all of the time, and the oliver 1955 and 1850 only run oil though the cooler when the valve is in nuetral, so the oil temp light comes on. im thinking of putting a tractor cooler of some kind on the rake and blowing air through it with a 12v car radiator fan. mabey even a combine cooler will work. i dont want to spend a fortune on a new cooler and was wandering if anybody had something cheap. (or mabey a better idea?)im thinking i need a 2' x 2' cooler with at least 2000 psi capablity.
BLH
10-19-2007 18:35:06
 Re: hydraulic rake problems in reply to pork, 10-19-2007 18:31:19
Sounds like you just need to put a power beyond on your Oliver tractors, check your owners manuals for each tractor, it should tell you how to do it.
pork
10-19-2007 19:07:43
 Re: hydraulic rake problems in reply to BLH, 10-19-2007 18:35:06
hadnt thought of that, but ill look into it
Dave in Tx
10-20-2007 11:20:59
 Re: hydraulic rake problems in reply to pork, 10-19-2007 19:07:43
If you put the cooler on the return hose from the motor on the rake, and use a size bigger hose, a standard hydraulic cooler will work. a good cooler 12 x 14,16 or 18 would be large enough. I have several used coolers if you need one. 3256427647 anytime.
Dave
