Round Bale Feeder
dj59red
10-14-2007 14:57:12
Now that I got my round baler 4X4 I need to find a Round Feeder that is not 8ft in diameter. What do other people use with these smaller bales?
Thanks,
DJ
Brokenwrench
10-16-2007 06:58:54
 Re: Round Bale Feeder in reply to dj59red, 10-14-2007 14:57:12
There`s a guy north of here who turns tractor tires inside out. Claims they make a great bale feeder and will fit a 4x4 bale..
Wilsonfire
10-15-2007 08:33:20
My cows just "Push" the feeder to the hay. Start out with the feeder against the side of the bale. They'll teach themselves. It doesn't seem to ruin the feeder.
Allan In NE
10-15-2007 04:58:43
Slickest method I've ever seen is the way my neighbor does it.
He takes an old flat-bed farm wagon, sets three bales on the thing, just pulls it out to his feeding area, pulls the hitch pin and lets it set.
Allan
low budget
10-15-2007 05:37:16
 Re: Round Bale Feeder in reply to Allan In NE, 10-15-2007 04:58:43
Used to do that too. Lot less waste and could move it to a different spot if it got muddy in the first spot. Worked good until a couple of big Holsteins got the bright idea of standing on it. Now I need a new floor. :>(
Tallperson
10-14-2007 15:19:24
I was wrong about the name ... Duuuh.. It is Hutchison not filson. Google up Flex bale feeders if they sound interesting to you... They work great for me.. And the will stand up to bulls as well as cows.. Sorry about the name mix-up... Tallperson
Tallperson
10-14-2007 15:13:41
I have used several types. The brand I like the best is a Filson , don't hold me to that name. THe feeder is made up of 4 curved panels that pin together. You can pull two pins and swing open 2 sections to put in a new bale. No need to drop it in over the top. Also as the cattle feed down the bale they can push the sides together until the 4 sections form a flattened figure "8". They clean up nearly every bit of hay. When you are not using them the panels can be seperated and tied up to a fence post to keep them out of the way for cleaning pens etc. Tallperson
