Square baler needle question
g_w_walker in M
10-11-2007 12:29:16
The needles on my Ford 530 baler are in good shape other than the twine has worn a groove in the lower part of the eye of the needles. It's about 1/4" deep. I have seen where folks have had their broken needles brazed and had no problems after. Has anyone ever tried to braze back metal in the groove and re-dress the needle eye to salvage them? Also got any idea why this groove was worn there in the first place?
Thanks for any ideas,
g_w_walker in MO
Briar Creek Stables
10-11-2007 12:48:28
 Re: Square baler needle question in reply to g_w_walker in MO, 10-11-2007 12:29:16
The grooves are from normal use. Twine is very abrasive.
I have filled the grooves in with either brazing or welding with no issues. You just have to make sure that you smooth out any surfaces that are going to some in contact with the twine. I used a dremel tool with a fine grinding stone on mine. If you leave the surface rough, it will snag the twine and make a mess of things
Dick L
10-11-2007 12:38:08
Miles and miles of twine?
