Overruning clutch yoke?
Help needed
10-08-2007 19:07:02
Back in the spring I bought a drum mower from C&C Machinery. It has a overrunning clutch built into the yoke that hooks to the pto of the tractor. I need one of this type of yokes for another implement. If anyone knows where I can find one I would appreciate it.
RodInNS
10-09-2007 05:10:42
 Re: Overruning clutch yoke? in reply to Help needed, 10-08-2007 19:07:02
Any A&I parts dealer can get one. A&I sells aftermarket parts by Weasler for Bondolini & Pavesi shafts, and that ORC is common on many Bondolini shafts.
In lieu of that, you can go to NH, Deere, and just about any other equipment dealer and an experienced parts man could probably cross that ORC to something they sell.
I'm guessing that you're looking for one with a standard 30mm cup and 70mm cross. (I think 70 mm is the cross width on a Class 5 shaft.) The class 6 shaft will have the same cup size with a 90 mm cross width I think... Needless to say, get a digital capiper and measure the cup size and the distance across the caps of the cross, and take that info with you in hand when you go looking.
It's a while since I bought one, but I can about guarntee you that 50 won't cover it. I'm thinking more along the lines of 150-200....
Rod
Tx Jim
10-09-2007 04:09:09
 Re: Overruning clutch yoke? in reply to Joe(TX), 10-08-2007 19:07:02
C&C Machinery has them as I bought one from them last year. Tx Jim
Briar Creek Stables
10-08-2007 19:21:00
TSC Tractor Supply Company has them for around $50
Help needed
10-09-2007 03:48:35
 Re: Overruning clutch yoke? in reply to Briar Creek Stables, 10-08-2007 19:21:00
I dont want the overrunning clutch that just slips over the pto and extends it. I want one that is actually made into a yoke that locks on the pto shaft.
Briar Creek Stables
10-09-2007 15:57:37
 Re: Overruning clutch yoke? in reply to Help needed, 10-09-2007 03:48:35
They have those as well. They're a bit more money, I think a little over $100
You can also find them on Ebay
