disk chisel
guck
10-05-2007 18:57:47
I have a IH 806 and a Case 1030 ( each right around 100HP). How big of a disc chisel could they handle. Are the only trailer or does someone make a mounted unit?
Thanks in advance
Jim Allen
10-06-2007 05:18:10
 Re: disk chisel in reply to guck, 10-05-2007 18:57:47
I pull a 8-shank mounted chisel behind my 826 (92hp). Like Don, I've never seen a mounted disk chisel. My 826 can barely handle the one I have (which is A JD Model 100 and was built with 11 chanks and with depth wheels. I like the mounted equipment because it gives the tracter the extra weight for good traction.
Don-Wi
10-05-2007 22:50:18
I've seen 3 pt. rippers, but never a mounted disc chisel. It'd be way too heavy in my opinion.
A lot depends on your soils. In our heavy clay, we pull 4-16's with our Oliver 1855 that puts out 105 on the PTO, and we can handle a 7 shank disc chisel. Even that at times can be a little much.
Most other guys on here can pull a 6 bottom plow with the same tractor, and can probably handle atleast a 9 shank. The best thing to do, would be find a dealer that rents them and ask what the other guys ussually pull them with, and then rent one.
We always just rent one, ussually it's a Brillion Soil Comander. Sometimes it a Sunflower unit. Same dealer sells both.
Donovan from Wisconsin
