477 New Holland Haybine and 53NAA Jubille
maze
10-05-2007 10:50:13
I asked the question bellow about 3 years ago
what model of haybine I can use with my 53 Jubille?
one of the answer was 477 new holland haybine, so When I see this haybine there is two pressure hoses must be for the hydraulic cylinder where would they go when the jubille has no connection for that?
paul
10-06-2007 22:07:45
 Re: 477 New Holland Haybine and 53NAA Jubille in reply to maze, 10-05-2007 10:50:13
Some few folks have taken the hyd cylinder out of the haybine & use a manual crank one. But, that does _not_ sound like any fun at all. I would not recommend it.
Fords of that era could have hyd remotes. Will cost you around $600 or more to fix your Ford up to be able to operate a haybine. Back when when you asked about it, I assumed your tractor would have the hyd remotes, as all haybines need an up/down hyd cylinder. Sorry we were unclear on that.
For making hay, it sure would be nice to have 10-15 more hp, and a little bit heavier tractor. You can get by, but both the haybine & baler would like live pto, bit more power, etc.
--->Paul
sammyd
10-05-2007 22:25:13
Save the Jubilee for raking, that"s about all it"s good for.
You might get by with a sickle mower and a crimper.
old
10-05-2007 11:18:42
Thats one of the problem with tring to use a MOCO behind most older fords they have no external hyds unless you can find a remote plate that bolts on and give you that option. They at one time made a plate that will bolt on and give you external hyds but they are not cheap and they can be hard to find
