Which 3pt 2 Stage Snow Blower for JD 4020 (80hp)gas?
wsimpson
10-05-2007 10:08:59
Needed to clear MN farmstead. If I try and pick one up at an auction, what should I look out for? Thanks.
paul
10-06-2007 22:14:48
 Re: Which 3pt 2 Stage Snow Blower for JD 4020 (80hp)gas? in reply to wsimpson, 10-05-2007 10:08:59
Got to farm sales, you can pick up a good 2-atage 8 foot wide unit for $500 - 1200. Most of them are about the same. This time of year, you will be looking to the higher end of the pay scale.
I happen to have a 7 foot single auger 2-stage blower as someone elese mentioned. I use it on my 27 hp compact tractor, or my 85 hp bigger tractor. Seems to blow about the same snow either way, the compact is a little more manuverable. The compact has a slower reverse. In heavy snow I can overload the blower with either, need to push the clutch now & then.
--->Paul - also from MN
RodInNS
10-05-2007 16:17:08
Look out for Allied, and avoid it like the black plague.
Pronovost, Normand, Lucknow, and Bervac are all good modern blowers that I see around. McKee is a good older blower. Pronovost would be my hands down choice for value if I was working it comercially. For limited use Lucknow would probably give better value. Pronovost is a heavy duty, well built blower...
Watch for worn out blower bands and small chutes. The bands will blow through and the small chute will create a lot of headaches in wet snow. Other than that, get a blower that will at the very least cover the width of your tractor's wheel tracks. If not you'll be stuck in a deep drift...
Worn chains and sprockets and other simple visible stuff would be the other things to watch. With blowers it's pretty well ya get's what ya sees. Inside of the gearbox is about all you can't see, and probably not much to worry about anyway.
Rod
Rick Kr
10-05-2007 11:55:12
All depends on wet snow or not.
I run a 7' single auger - 2 stage on a NH 3930 (47HP). Does fine in powder. Heavier snow I don't have the power.
Can't wait for snow this year, I am putting it on my new to me AC 7000 (105HP).
So what to buy, I have owned 3 blowers over the years. They are all pretty simple. I just check the bearings and the gear box. The rest is just sheet metal. Easy to straighten. Don't ask how I know.
5 footer $700(2001), 6 footer $700 (2001), 7 footer $550 (2003). All of these needed nothing other than a little paint.
Rick
M Nut
10-05-2007 11:31:13
I use a 2 stage dual auger New Idea on the back of my 4020 and that is one snow movin' machine. In deep drifts it will pull my diesel right down to her knees. I really like the blower though!
