New Holland 479 Problems
Roby
10-04-2007 18:13:13
I was cutting this evening and stopped to remove a clump of hay and dirt from under the cutter, not thinking I started the PTO while the engine was idling about mid range, after that I noticed that the sickle bar and wobble joint were still working, however the rollers are no longer turning, have found what I believe to be a clutch disc just outside the gearbox, it looks to be missing some pins, not sure waht size or how they are to be replaced, any help is appreciated.
Our Farmer
10-05-2007 05:58:10
 Re: New Holland 479 Problems in reply to Roby, 10-04-2007 18:13:13
A lot of guys just weld up that overrunning clutch and be done with it.
Model 12
10-05-2007 04:34:42
I had something similar happen to mine last week. The wobble box still moved but the reel & rollers didn't. The problem was the keys in the roll sprockets were gone / had sheared. If that is the case on yours, you need part # 129295 gib key for each sprocket. It's a tapered key that's driven in.
