Need help on JD Model FB 13*7 Grain Drill
Too Far Gone
10-04-2007 13:41:14
Ive borrowed neighbors John Deere 13 by 7 Model FB Drill to sow wheat,and he lost his book.If You have a book,I would appreciate help on wheat settings for 2 bushel per acre setting.Thanks
dobber
10-04-2007 18:33:35
 Re: Need help on JD Model FB 13*7 Grain Drill in reply to Too Far Gone, 10-04-2007 13:41:14
That's what the chart said for average size grain and US weights per bushel and using 7.60-15 passenger car tires. When using other tires there is a correction factor you multiply times the pounds of seed you want to plant to get right with the chart settings. With 6.70-15 passenger car tires or implement tires the correction factor is 1.04. With 8.20-15 passenger car tires the correction factor is .95. So for example you wanted to plant 82 pounds of wheat with 6.70-15 tires you use correction factor 1.04. 1.04 x 82 = 85.28 or 85 pounds. So set notch at 16 to get about 85 pounds. This will all vary on seed size, how clean, and tire size height. 13x7 drill with 6.70-15, 4 ply tires inflate at about 19 pounds.
TGIN
10-05-2007 03:11:30
 Re: Need help on JD Model FB 13*7 Grain Drill in reply to dobber, 10-04-2007 18:33:35
What size modern tire would be the the same as the 7.60-15 ?
dobber
10-06-2007 00:02:33
 Re: Need help on JD Model FB 13*7 Grain Drill in reply to TGIN, 10-05-2007 03:11:30
If you shop around can still find 6.70, 7.60, & 7.50 rib implement tires. Use 4, 6 or 8 ply adjusting air pressure to get correct height. FB manual doesn't tell axle height that I saw but on most all other later JD end wheel drills you just adjusted tire inflation to get 13 1/4 inches from center of axle to ground surface with 15" tires and 17 1/4" with 20" tires.
dobber
10-04-2007 18:13:26
For FB 7" spacing the chart in manual shows for wheat: Notch 4 = 18 lbs., 8=39, 12=61, 16=84, 20=108, 24=132, 28=155, 32=180, 36=205, 40=236, 44=268, 48=281. So for 120 somewhere between 20 and 24 notch for 7" spacing and between 24 & 28 for 8" spacing drill. Set the feed gates lever in front of flute cup in the LH upper notch for wheat, oats, barley, rice, rye, buckwheat. Open the gates more for trashy grains or larger grains. For JD manuals call direct 1-800-522-7448.
Too Far Gone
10-05-2007 06:18:46
 Re: Need help on JD Model FB 13*7 Grain Drill in reply to dobber, 10-04-2007 18:13:26
Thanks a bunch Guys.
j105
10-04-2007 16:14:25
I'm going from memory here but i think to put on 90 lbs. you set it on 16. (thats what we normally sow around se kansas) so 120 would be somewhere around 18 or 20. i'll check tommorrow and get back
Too Far Gone
10-04-2007 16:23:29
 Re: Need help on JD Model FB 13*7 Grain Drill in reply to j105, 10-04-2007 16:14:25
Thanks a lot
Gerald J.
10-04-2007 15:06:28
My book is about 8 miles away. Doing oats seems to me 2 bushels was right around mid scale. What you can do is jack of a wheel, turn it ten times with the drill in gear, catch and weight what gets measured out and adjust from there. I did that refine my drill settings even starting with the book that recommends some other checking to be sure of the rate. This is because the drill is a volume measuring tool while the seed is measured in pounds... and the weight is different for different sources of seed.
Gerald J.
Too Far Gone
10-04-2007 15:34:50
 Re: Need help on JD Model FB 13*7 Grain Drill in reply to Gerald J., 10-04-2007 15:06:28
Thanks for the reply.I know it'll take a little adjustment,always does,but Ive never used one of these drills,and need approx setting from the book.
