Homemade landslide for plow.
Jeff McIntosh
10-01-2007 04:57:05
Since I've had no luck finding the furrow wheel for my IH 531 plow's it has been suggested to use a plow point and fashion a long landslide from it.
Has anyone done this? Do you drill new holes for mounting in the plow bottom or can the plow point be drilled?
Jeff
TomTex
10-01-2007 05:46:10
 Re: Homemade landslide for plow. in reply to Jeff McIntosh, 10-01-2007 04:57:05
I would use a piece of flat bar mild steel of the measurement you need. It will be easy to shape and drill holes. Then use a good DC stick welder and hardsurfacing electrodes to put a hard surface layer on the bottom edge, and a little bit of the outside edge. Will last almost forever. I bought an OEM landside and hard surfaced it with Lincoln electrodes to prevent wear. Tom
Jeff McIntosh
10-01-2007 07:01:19
 Re: Homemade landslide for plow. in reply to TomTex, 10-01-2007 05:46:10
TomTex.
Thanks for the quick reply. Mild steel would be much easier to work with. We have a DC welder at work so I'd just have to buy a few hard facing rods.
I'm going to look at my Dad's AC plows to get some idea of the general shape then go from there.
Jeff
