new holland 835
mike kinsella
09-28-2007 03:27:03
i am about to buy a big baler nh 835 for about 1600 dollars its 14 years old--any views on this make of baler? good or bad?
mike kinsella
10-01-2007 14:20:38
 Re:thanks Allan in reply to mike kinsella, 09-28-2007 03:27:03
Many thanks for your help and support and patience i am gonna give it a go and hope alls well - but will check the bladders!
Mike
mike kinsella
09-29-2007 09:50:06
 Re: new holland 835 in reply to mike kinsella, 09-28-2007 03:27:03
Allan
if you would be kind enough to google up New holland 835 there is an excellent video on youtube.
many thanks
Mike
Allan In NE
09-30-2007 06:26:13
 Re: new holland 835 in reply to mike kinsella, 09-29-2007 09:50:06
Hi Mike,
Appears to be a minature version of the 853. Probably makes a 42" bale?
If the chain seems to be "lop-sided", I'd check it for being out of time with itself. It has to run true on both sides of the chamber. Maybe someone started it running without the bladders being aired up?
Allan
mike kinsella
09-28-2007 23:02:35
Yes am in uk- can you tell me about the air pressure and what it does - it looks like one side of the roller set up looks lower than other- is this an issue or does it correct itself when baling??
Allan In NE
09-29-2007 05:43:09
 Re: new holland 835 in reply to mike kinsella, 09-28-2007 23:02:35
Mike,
Do you have a picture of this rascal?
Hard to comment on a piece of machinery without knowing exactly what you're dealing with on your end.
Allan
mike kinsella
09-28-2007 11:01:56
Thanks bit its definitely 835- does that change things?
Tim(nj)
09-28-2007 16:48:25
 Re: new holland 835 in reply to mike kinsella, 09-28-2007 11:01:56
My research so far indicates this is a European baler that was not sold new in North America. It is a chain baler, though, similar to an 853. So either you are on a continent other than NA or you've got a grey market baler . . . .
Allan In NE
09-28-2007 05:32:12
835 or could you possibly mean 853?
One of the last NH chainers, it is a lighter, smaller version of the 855. If it is the electric "bale command" baler, be sure and get the brain box.
Look the chains over, set the air pressure at 40 lbs., make all the adjustments as necessary per the manual and go bale. :>)
Allan
