implement conecting to ford pto shaft
Ethridge
09-27-2007 08:09:47
while my husband was mowing at the huntting club the implement shaft disconnected from the ford pto shaft. we went and got the pin to go back into the implement shaft that conects to the tractor pto. but now when we conect the two the implement fitting over the pto is not tight. it does not give a tight fit. Whats wrong with it?
Oldmax
09-28-2007 05:58:02
 Re: implement conecting to ford pto shaft in reply to Ethridge, 09-27-2007 08:09:47
Some fords have a 1 1/8- 6 spline and some have a 1 3/8 - 6 spline determine witch you have . If you have the smaller you will have to use an adapter that can be purchased at your local tractor supply store . There can be some play in splines but not excessive .
Chad Franke
09-27-2007 10:02:03
Make sure they are the same size. The little Fords used an 1 1/8 inch 6 spline shaft, most implements use a 1 3/8 6 spline shaft.
old
09-27-2007 09:48:40
Look close at the splines on both the PTO shaft of the tractor and the internal ones of the other shaft and see if they are worn badly. If so one or both should be replaced because they will keep working on each other till one or both get to the point that they will slip and then cost even more to fix
