224 square baler
crisok
09-26-2007 10:55:43
I was baling with my 224 john deere square baler.
The Shear Pin broke but it also broke the brake drum on the knotter wheel. What could have caused this?
Tx Jim
09-27-2007 03:35:26
 Re: 224 square baler in reply to Dan Witt, 09-26-2007 10:55:43
crisok,if you are refering to the needle lift shear pin,it's a brass pin with cotter key hole in each end. It's been to long since I was a JD parts man to remember part #. Tx Jim
Dave H (MI)
09-26-2007 14:00:22
 Re: 224 square baler in reply to crisok, 09-26-2007 10:55:43
I can't get to my manual or my baler at the moment but is it possible that someone might have put a bolt in there that was a little tougher than the specs suggest? Check out the bolt and your manual and see if this is the case.
crisok
09-26-2007 15:30:08
 Re: 224 square baler in reply to Dave H (MI), 09-26-2007 14:00:22
Don't have a manual on this machine what kind of bolt does it suggest you put in this machine?
Bob
09-26-2007 16:57:24
 Re: 224 square baler in reply to crisok, 09-26-2007 15:30:08
Probably a special "shear bolt" with a specific DEERE part number.
