3.50 x 12 inch Rubber Plow Tire Needed
Plowman0901
09-25-2007 19:16:31
Looking for some new 3.50 inch x 12 inch ribbed or implement style 4 ply tires for the rear wheel off an old pull type plow. I know Miller Tire has these types of rubber tires but I am looking for a more affordable tire. Brand of manufacture does not matter. Any comments, suggestions, or ideas would be appreciated. Thanks!!
Leroy
09-26-2007 17:55:17
 Re: 3.50 x 12 inch Rubber Plow Tire Needed in reply to Plowman0901, 09-25-2007 19:16:31
Just go buy a wore out for road use 4:80 X 12" boat trailer tire and that will work just fine.
Plowman0901
09-26-2007 19:04:43
 Re: 3.50 x 12 inch Rubber Plow Tire Needed in reply to Leroy, 09-26-2007 17:55:17
I used a bigger tire and come to find out anything bigger than a 4.00 x 12 tire rubs against the axle. Some plows you can get away using a 4.80 x 12 tire but the majority of them require using a 3.50 x 12 tire.
Leroy
09-27-2007 05:49:52
 Re: 3.50 x 12 inch Rubber Plow Tire Needed in reply to Plowman0901, 09-26-2007 19:04:43
I have never seen a plow you could not use that 4:80 on. If you can't get it on and work then I would check for something bent. I had JD, DB, Oliver, Moline, IHC, Case, MH, AC and they were all made so that tire would work. Ford and Ferguson did not use a rubber tire on the tail wheel.And due to the different way of measuring the ag tire to the road tire they actually are verry close to the same size. What Model plow do you Have?
El Toro
09-26-2007 03:57:23
Try Tires Unlimited at 1-800-62-TIRES. Hal
