25V Outer Shoe
Brad Bachelor
09-24-2007 05:16:18
I dont know what happened, but I lost the outer shoe (the one next to the grassboard) on my Mccormick 25V mower when I was headed to the hayfield. Does anyone know where I can get a replacement?
I mowed the field without it, but I sure don't want to wear out the bar.
Thanks,
Brad
Curt from MN
09-24-2007 10:02:53
 Re: 25V Outer Shoe in reply to Brad Bachelor, 09-24-2007 05:16:18
Try your Case dealer. Outer Shoe is part #MF729AX. Will probably need the Sole which is part #M259X.
https://webparts.pvassociates.net/cnh/main.php gives part #'s and pictures of equipment. Parts for the 222 Rotary will work for the 25V.
Brad Bachelor
09-24-2007 12:53:57
 Re: 25V Outer Shoe in reply to Curt from MN, 09-24-2007 10:02:53
Turns out all I needed was the sole. Thanks, I thought a 60 y/o part would be unavailable new, but $27 later I can pick it up on wednesday.
Curt from MN
09-27-2007 16:20:28
 Re: 25V Outer Shoe in reply to Brad Bachelor, 09-24-2007 12:53:57
Should have mentioned to get the bolt and nut!. Bolt is part # D266X. The bolt is square head and slides into the Shoe. My bad, I thought the Sole slid into the Shoe then was bolted tight. Not so. The bolt slides in the groove of the Shoe and the Sole rides on the outside of the groove then is tightened down by the nut on the bolt.
