plow land wheel
StuBC
09-22-2007 14:49:22
I have a David Brown 3ph 3 bottom plow with no land wheel. I cant tell if there was one ever, but there is a picture I saw from here that showed one. But most of the plows I see if not all have a rear land wheel. I am learnig to plow, and I would like advice if I should make one. I do have a steel wheel from a mining track that I could make into one. Advice? Do I need a land wheel? Makes sense to line up the bottom on re-entry.
ktheo1
09-23-2007 06:09:32
 Re: plow land wheel in reply to StuBC, 09-22-2007 14:49:22
The tail wheel on a 3pth plow was actually a rolling landside and not used for depth control.
If you don't have one you will have an exrta long landside on the rear bottom .
StuBC
09-24-2007 09:41:24
 Re: plow land wheel in reply to ktheo1, 09-23-2007 06:09:32
I do have an extra long land side on the rear, so I guess I am good.
Thanks all.
johns48jdb
09-22-2007 16:31:26
scroll down a few post and read post on setting up plow.
caterpillar guy
09-22-2007 14:56:54
No you don't need it just get the plow level at the depth youwant and go.
