International sickle bar mower 7'
MC in KY
09-17-2007 11:54:57
I was given an old International sickel mower by a friend to cut around my pond and ditch banks. It is belt driven but has no numbers or stickers on it to identify the model. I need some parts to make it work but need help finding out what I have. Is there any way I can find this information??? Also where do I get parts for this type of mower... I need that big spring with a bolt on one end and the piece on the end of the mower that holds the swath board, as well as gaurds and sections.
I would appreciate any help concerning this mower.
MC in KY
09-19-2007 04:50:55
 Re: International sickle bar mower 7' in reply to MC in KY, 09-17-2007 11:54:57
It is a 3pt hitch that is made from flat iron. I am trying to get some pitures on here but I am having a hard time posting them.
Did International also make a 9 ft mower?
Dave H (MI)
09-18-2007 16:53:36
How about a couple of pictures?
Clefus
09-17-2007 19:47:16
I have a 27v I re did last winter ...
I replace half of the ledger plates instead of the entire guards....new knives....new pitman bearing ( close to $50 at Case ) ...Im ditching the lift spring and putting a lift cyl on it( if I get to it this winter)...it was a factory option....re bushed the drawbar...well worn....welded some stuff...new paint....I'll try it next spring if I get time after getting hay in..
newbie haymaker
09-17-2007 17:55:12
i have a three point 7 ft int sickle mower. You can get the swather? the end piece at tsc. the model number on mine is a 1300. yours sounds like mine if it is a three point.
Leroy
09-17-2007 17:15:49
To come up with a model we will need more information. Pull type on 2 rubber tires? Semi mount on 1 caster wheel? full mount 3 point hitch? Fast hitch? Side mount?
