Ford 530 baler problem
ddk114
09-17-2007 11:35:03
Hay balls up on the inside of the pickup just short of where the forks can get it. It almost turns like a tornado as hay moves behind it from the outside fork. I see that the forks closest the bale chamber has one tine (closest the tractor) six inches shorter than the others. It was made that way. We've fed about every different way possible to eliminate the ball. The ball eventually blocks the feed into the chamber. Any suggestions?
georgeky
09-17-2007 22:06:49
 Re: Ford 530 baler problem in reply to ddk114, 09-17-2007 11:35:03
The feeder fork is made that way. Check your pick up reel for missing teeth close to the chamber thraot. When some are missing there it will cause this problem.
ddk114
09-20-2007 13:31:34
 Re: Ford 530 baler problem in reply to georgeky, 09-17-2007 22:06:49
Fund no teeth missing. Made the short fork longer like the others. Works better than new.
