Guess I Messed Up
scott#2
09-12-2007 19:21:25
I was at a sale today and saw a NI 12A manure spreader sell for $200. The paint was rough but the mechanics were all there and looked operable, everything turned right. There was a fair belley in the pusher chains and bars on the under side of the cart that push the stuff back to the spike rollers and beater bar , guess a link could be removed? Floor and sides were solid and it looked like it had been used recently. I guess all the NI spreaders of that era had basically the same moving and throwing arrangement back at the business end and on the floor? Seems like when I used to see them working, it threw a wider swath of manure out than the cart is, like 8 or 10 feet wide, right?
Oh well, better luck next time I guess.
scott#2
Briar Creek Stables
09-13-2007 10:11:33
 Re: Guess I Messed Up in reply to scott#2, 09-12-2007 19:21:25
In this area a spreader like that even at auction would go well over $1000. A spreader in good shape that can be used or easily repaired has a good price tag on it here.
When I was looking for a spreader last year. I figured I could pick one up for a few hundred and be good to go. Every spreader I looked at the was in working order was $2000 +
I ended up buying an old John Deere spreader that was litterly falling apart for $400. The wooden floor was gone, the sides were rotted so bad that you couldn't even haul firewood in it without losing your load withing 20 feet.
I put a new floor and wooden sides on. This spreader sort of runs. The biggest issue I have is the dogs that ratchet the bed chain back are shot. If I get a real heavy load in there, it will set there for a good 15 minutes or so before it moves back 1 inch. It makes for a long day. The spreader is so old that parts are impossible to get and usually you have to get a piece of metal and make your own.
I would of loved to come across the spreader you're talking about for only a couple to $400. Then I would of enjoyed watching my old spreader being crushed.
paul
09-12-2007 19:43:42
Sounds like 1/2 price for what a spreader brings 'here'.
Many want loose chains - certainly not tight anyhow. Almost all spreaders have adjusting sliders up front on the idler sprockets. A long draw-bolt on each side. One can take a link out, but likely it was 'normal'.
--->Paul
scott#2
09-12-2007 20:00:25
 Re: Guess I Messed Up in reply to paul, 09-12-2007 19:43:42
Yep, I knew you were gonna say that. You never know where it will stop when you jump in though, could have been $400, I guess thats my top price. I just didnt feel like driving back up there with a trailer to fetch it, plus, I'm still kinda learning about them. Next time, Ill know. I guess all those older, 2 number spreaders do about the same job?
Thanks Paul,
scott#2
paul
09-14-2007 09:23:28
 Re: Guess I Messed Up in reply to scott#2, 09-12-2007 20:00:25
I have a - um, 19??? Worked well, chain started breaking, debating if it is worth a new one.
I know on auctions, I let a lot of good deals go for the very same reasons. :)
You catch a good one once in a while too. I bought a set of pie wheel weights for my Ford a few years back, with the discs & special nuts. All for $12.50. Folks here tell me it's worth $400-600.
--->Paul
