jd 510 baler
newbie haymaker
09-10-2007 17:10:18
Just had a buddy buy an old 510 baler, Shall we say "needs a little work". Any input such as age, quirks, or location of closetest scrap yard.
thanks
Old Iron
09-11-2007 19:04:34
 Re: jd 510 baler in reply to newbie haymaker, 09-10-2007 17:10:18
I've got a JD 510 and the only time it plugs is if I don't see a wrist-sized (or bigger) tree limb in the windrow. Also if the hay is too green it wraps around the rollers (like most other balers), other then that it works just fine.
phillip d
09-11-2007 17:45:03
They are tough balers to opperate.Conditions need to be PERFECT at all times or you will be pulling alot of stuff from the front and will likely have to use a pipe wrench on the shaft drive to free it up.pd
Walter Squires
09-11-2007 09:14:46
I bought a new one in the early 80s, traded it off a year latter for a 1560 Massey which is the same as a 605F Vermeer, I thought I had died and went to heaven. Those JD 510 and 410 just would not bale fescue in this part of the country, trust me you don't want a closed throat baler of any color.
georgeky
09-11-2007 15:53:06
 Re: jd 510 baler in reply to Walter Squires, 09-11-2007 09:14:46
Baled thousands of rolls of nothing but fescue with no problems.
georgeky
09-10-2007 21:19:59
I have an old 510 and it is a good baler. Don't roll as tight as some of the newer ones, but works good. They were made in the late 70's and maybe very early 80,s
billonthefarm
09-10-2007 18:17:04
I have a 510 and get along fine. I suppose I have only baled maybe 30 bales with it this year but I have also baled 100 in a day before without any trouble. Mostly use it when some hay I wanted to put in squares gets rained on or I just dont have time. I bought a pretty nice 510 cheap and just put a few parts on it every year and try to keep it up in good shape. It is easier and cheaper to have this old baler around than it is to wait and pay for the custom balers. That being said I wouldnt buy one that needed alot of work and go into the baling business but it works out good for me. bill
KEH
09-10-2007 17:40:00
I've never used one, but from comments on here and from talking with people locally, it has many problems. Hard to start bales unless hay is at right stage, parts expensive, and it is old. It seems the different manufacturers didn't start making really good round balers until the late 1980s. Hope he didn't pay much for it. You could do a search on here for 510 baler threads.
KEH
