Kverneland Plows
Freind of the
09-07-2007 12:10:02
Can anyone tell me where I can get shears for a Kverneland 4 bottem Plow.
jimont
09-07-2007 15:17:23
 Re: Kverneland Plows in reply to Freind of the farm, 09-07-2007 12:10:02
If you have an eary Kverneland plow, you might find the shears are now discontinued. I have two from the mid sixties and shears are no longer available (I went right to the distributor here in Ontario).
Dave Sherburne NY
09-07-2007 15:14:20
Try This my son was the parts man at a Case IH dealer. Go to this website, to the parts manuals
type in plow for the model number, then select
7500 Case IH moldboard. Then select Chassis, then
select 09-16 moldboard bottom HSES high S which is high speed European. This will give you the number for the shares very expensive Be sure you
get the reversible share point which bolts to the regular share and makes the share last longer. Of course you could find a Kverneland dealer somewhere But that might not be easy depending on your location. Questions, Email me.
RodInNS
09-07-2007 19:25:53
 Re: Kverneland Plows in reply to Dave Sherburne NY, 09-07-2007 15:14:20
Don't take this the wrong way.... but when I read your post I got the impression that there was one Kverneland share. Mabey I took it up wrong...
In reality there are probably 20 different bottom STYLES used over the years, and as many as 6 or even 8 different shares for each body style depending on the width. There are many, many multiples of combinations possible.
The simpliest way to get the parts is to remove one share and get the Kverneland number off the back side of the share. That's the actual part number. Give that to the parts man and go from there. That goes for any other wear part on those plows.
Molboro also makes many wear parts for those plows, so if a guy was STUCK he could try them. I don't make a practice of using Molboro parts. They don't have the process in the steel and they don't last like genuine parts. They are cheaper, and it probably comes out in the wash cost wise, but it's an inconvienence to have to change wear parts more often; sometimes in the field. I don't care for that. I can get the day from a set of genuine tips... but not the Molboro tips, so it's worth a few extra bucks up front to me.
Rod
Freind of the farm
09-07-2007 15:04:30
Thanks I will try those sites.
RodInNS
09-07-2007 14:12:13
Any authorized Kverneland dealer. Google them. You'll probably find their main site and do a dealer search... If you're in an area where Kverneland plows are prominent that probably any respectable ag dealer will handle Kverneland...
Rod
El Toro
09-07-2007 12:42:07
You can try these places. Hal
707-678-5533
231-924-3420
