NH 479 haybine
RodN
09-07-2007 06:43:56
The yoke on my Haybine wobble box lost a bearing last weekend.
I appears that I will have to replace the yoke and verticle post and associated bearing and collar. The yoke is just riding the post after the bearing disintegrated.
Is this something I can do or does it need to be replaced by a repair shop that must line everything up perfectly. I thought as long as I have to dismantle the horizonal bearings attached to the yoke I'd might as well replace all the bearings.
Stephmn
09-08-2007 04:46:07
 Re: NH 479 haybine in reply to RodN, 09-07-2007 06:43:56
You should be able to do the change out,pretty straight forward. I believe the bearing # are 2 of "set 2" (LM11979 & LM11910) for the end caps,1 of "set 13"(L68149 & L68110) & 1 of set A40 (JLM104946)
