Wagon hitch for JD 14T baler
Rick WY
09-06-2007 17:39:17
I"m looking for a wagon hitch to mount on my JD 14T baler. Several of the older JD balers (14T, 24T, 214T, etc.) would have had similar hitch setups. The baler has the plate for mounting the wagon hitch connection on the axle. I understand there were two set-ups available - side hitch and center hitch, Both styles shared some common components. If someone has a complete hitch or knows of one, I"d be much obliged for any information. Thanks.
Randy-IA
09-09-2007 11:08:44
 Re: Wagon hitch for JD 14T baler in reply to Rick WY, 09-06-2007 17:39:17
Hi, I'm not trying to be mean or anything but are you looking locally ? Those parts are heavy so shipping will cost more than they are worth . Making one shouldn't be a problem for a good welding /fab shop . Get the parts manual to see what they look like and do your own measuring . A couple pieces of tubing and some thick angle iron and a good welder is all you need . I think you should be able to find one locally though if you don't want to go that route . good luck ! ...Randy
