JD 4400 Combine ready for maiden Voyage ?!?!?!?!
The Red
04-03-2000 11:15:36
third party image
Got ol Corey to sweep out the cab for me. Pretty clean for a 29 year old combine.
See if y'all can think of anything I haven't checked.
1. Engine and transmission OK. Oil and Coolant are still at the top with no leaking nor burning of oil.
2. Tires are aired up and power steering is working great.
3. Transmission and differentials are full.
4. Brake fluid reservoir full and the brakes are bled. They don't work very good though.
5. I will add 10 gallons of gas prior to heading home. The trip will take 4 miles.
6. Lights and flashing lights inop. along with no radio.
7. Tach and water temp. gauges are inop. I have run the engine 30 minutes on 5 separate occasions and have not seen any boiling over. Think I'm safe?
8. No Hydraulic leaks! The second hydraulic steering line showed no leaks after replacing the first one today. Don't see any hydraulic leaks anywhere at all.
9. Grain table rises nicely and stays up all the time with no sagging. That is my emergency brake.
10. Cell phone is charged.
11. Planning on a police escort, being Indianapolis, and my retired mechanic will be there with his tow truck just in case.
Anybody think of anything else?
Butch
04-16-2000 09:49:14
 Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-03-2000 11:15:36
Movec a combine with 15' header from south of Rochester Mn. north about 40 miles. Asked for police escort and was denied, so drove right through downtown on a Sunday morning. People don't pass, hope they wer'nt late for church.
john d - ONE MORE IDEA!
04-08-2000 10:32:20
Red, PLEASE CONSIDER MOUNTING YOUR CAMCORDER ON THE BEAST! Shouldn't be too hard to rig a quick mouting attachment on the cab somewhere, and just let the tape roll for the entire trip!! You might get some really good footage of things, and you'll certainly have a record of the trip from the perspective of the cab. Since you won't be driving it yourself, it would be the next best thing to being there! This could turn out to be even better than your article on overhauling the H!
Somewhere on the cab or close to it you should be able to find a spot to run a bolt through and into the bottom of the camera. Most of the ones I've seen have 1/4" threads, so a bolt, a couple of washers and two nuts, one to hold the bolt firm in the combine, and one to lock the camera in place, should do it. You can always cushion it a little with a layer of old innertube, or something similar. If all else fails, pad it with a couple of kitchen sponges and DUCT-TAPE the thing onto the side of the ladder!! There shouldn't be enough vibration to hurt it; another guy and I mounted one on a go-kart once and got some really neat footage! That should be a lot worse environment than on a combine!
You'll end up with a treasured memento of the trip, and something Corey will show HER grandkids someday!
The Red
04-08-2000 10:42:10
 Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to john d - ONE MORE IDEA!, 04-08-2000 10:32:20
I'll think about that John. Not a bad idea. I could leave the engine deck down and mount the camera on there. Now if I can remember how to operate that durn video cam!
john d
04-08-2000 10:59:38
 Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-08-2000 10:42:10
Just make certain that whatever you mount it on moves with the combine, and doesn't bang or swing around when the machine is in motion! You'll get a better video this way than if you rode on the machine and held the camera.
Find a couple of other folks to borrow cameras from, and you could have the makings of a feature film! Edit the thing down to a clean documentary, and Kim would probably sell the thing here on the YT site!
The Red (foot tapping)
04-08-2000 11:02:27
 Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to john d, 04-08-2000 10:59:38
I'm still waiting for the checks from my 2 articles.
john d
04-08-2000 11:08:48
 Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red (foot tapping), 04-08-2000 11:02:27
Red, this could launch you into a brand-new career! You could be the next Spielberg if you pull this off!
Look at it this way..... if something bad happens on the trip, like a wheel falls off at 10mph, the ride captured on the tape will win you $10,000 on Funniest Home Videos!
Hunger has hit. I'm gonna head for Steak & Shake and get some nourishment before finishing up what work has to be done in here today. Maybe I'll think even more clearly on a full stomach!
The Red
04-08-2000 11:13:00
 Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to john d, 04-08-2000 11:08:48
I'll take a steak cheese burger with fries please!
john d
04-08-2000 13:31:58
 Re: Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-08-2000 11:13:00
I ate your share too.
Have you considered what a neat video you could get if you headed that thing up on the interstate for a short trip, or simply waited until 500 race day to move it?
tim[in]
04-09-2000 01:12:01
 Re: Re: Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to john d, 04-08-2000 13:31:58
hmmmmm . living on the est side of indy ,i will say it will be interesting. i know because i've moved a pull type combine and a 4 row planter around 465!1 try pulling 2 box bed wagons through indpls and then down 67 to where i store them !!lol what is really bad is in the early am hours have a front mounted 2 row cultivator fall off the trailor. the 1 row picker and combine and planter trailed pretty good i thought !! the only thing that attreacted police attention was the 2 wagons around midnight going past mooresville down 67 !!lol
The Red
04-09-2000 03:45:59
 Re: Re: Re: Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to tim[in], 04-09-2000 01:12:01
What did you do. Stop at Gray's cafeteria in Mooresville????? ????
tim[in]
04-09-2000 17:36:46
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-09-2000 03:45:59
no . might have to try one of these days though !! lol if they put in a drive through . have taken a white 2-105 and a sprayer thru the banks drive thru tho !!lol you should have seen their faces !!=)
The Red
04-10-2000 07:15:16
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to tim[in], 04-09-2000 17:36:46
After I finished Corey's Farmall H last year, I drove it down Crawfordsville Road and gassed it up at Rob's Marathon. That got a couple of looks.
tim[in]
04-11-2000 01:05:48
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-10-2000 07:15:16
but did you get the 4400 jd home? we waiting to hear about that?how was the trip ? inquiring minds want to know !! lol =)
The Red
04-11-2000 01:40:10
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to tim[in], 04-11-2000 01:05:48
Not yet. Stay tuned.
Dave K.
04-08-2000 10:05:26
John:
I would add a stick to your list; to chase away the boys who will be hanging around--that's assuming Corey is going on this voyage with you.
I'm not sure this is progress: going from flying jets around Oklahoma to driving a Combine for 4 miles in Indy. It does look like you just can't break the habit of filing a flight plan though.
Try not to burn rubber on your startup
The Red. ROFL!
04-08-2000 10:10:17
 Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to Dave K., 04-08-2000 10:05:26
Thanks Dave. Corey is riding with me in the pickup and I will be in tow to pick up falling parts. Found a farmer who will give me a hand and I am going to let him drive it since he is use to driving down Indy streets in his 4400 and 6620 combines with grain table attached. I'm use to the wide open country roads. I'll make sure he DOESN'T do a deck takeoff. :)
Ted
04-08-2000 07:58:05
Drive it home. Only 4 miles. I've driven a combine a lot farther than that.
Forget the police escort, I think it might actually make things worse, but it might get you on the news. Just think, Combine chased by Indianapolis police dept with lights and all flashing. It'll be the biggest thing since OJ.
Seriously, Just drive it home. Have someone follow you with their flashers on. Stay off the main roads if possible. And have a good time cuz you'll have a lot of people going--What the Heck is that and What is it doing here?!!
The Red
04-08-2000 08:39:06
 Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to Ted, 04-08-2000 07:58:05
Well Ted since I posted this, I found a nearby farmer who runs his 4400 and 6620 on Indy streets all the time with headers attached. We are hoping to move it tomorrow with him driving, since he is use to battling mailboxes and road rage drivers, and I will follow to pick up pieces that fall off. We have no choice but to take two very busy streets. There is no way around it unless I hired a Chinook helicopter! It is suppose to be in the mid 50s tomorrow afternoon and Indy traffic is at it's lightest on Sunday.
tim[in]
04-09-2000 01:23:49
 Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-08-2000 08:39:06
wish i had found this forum earlier! i've taken a wd allis and a 1 row pull type picker and 2 wagons hooked behiund that down us 52 before. i drive a fuel oil truck around indy for a living.so i know about the drivers !!lol i used to work for 2 farmers on the east side of indy for 20 years and can attest for the mailboxes.especailly!! they love to stick them out in the roadway on the east side . lots of fun with a 16' 6 row cultivator!!and try the 155hp tractor and 22' fold up disc and dual wheels and a school bus coming from the other direction !! at least the bus driver now knows she CAN drive on her side of the road !!lol remember your smv and watch the bridge abutments. and also make sure ahead of time they arent working on the road you want to drive down. the bridge that was on southeastern over 465 on the se side is no more as they are going to replace it ! .good luck . let us know how it turns out. of course maybe i'll see you on the news !!lol=)
The Red
04-09-2000 03:49:05
 Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to tim[in], 04-09-2000 01:23:49
Thanks Tim. I was down 52 the spring of 98 and looked at a stuck, beat up Farmall M near IN 9. Ol boy wanted $800!!!!! !!!!!
tim[in]
04-09-2000 17:39:49
 Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-09-2000 03:49:05
i saw a farmall M with a mounted picker advertised in fountain town . that area is considered fountain town. i wonder if it is the same tractor?
The Red
04-10-2000 04:38:43
 Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to tim[in], 04-09-2000 17:39:49
Nope this was a stand alone near Shelbyville.
Tom S.
04-04-2000 14:22:20
Red; Do like Dave below suggests and put the header on a trailer. It is not all that heavy, and you can pick it up with a boom pole. The scare of meeting a car topping a hill isn't worth it. You will always meet a dooley or something in a blind curve. Measure, but I think that header will might near fit on a regular old 14 X 6 1/2 bumper hitch trailer. My Massey header is 13 1/2' overall, and is almost exactly 6 1/2' long laying flat with the reel clearing the sides. Fits a standard angle iron trailer perfectly.
Glad to see you did not sell it. Tom S.
The Red
04-04-2000 14:45:22
 Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to Tom S., 04-04-2000 14:22:20
Tom it is still for sale but no takers. My 4.2 mile trip is on level straight roads with no blind spots so no problems there. Thanks for expressing the concern.
Tom S.
04-05-2000 06:22:26
 Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-04-2000 14:45:22
Red; Just you wait till it's finished. Every body and his cousin will stop and look at it, and want to buy it. As long as my Massey swather was a rusted hulk, every body wanted to have my place condemed, but now that it's finished I answer questions about it all the time. Tom S.
The Red
04-05-2000 07:14:47
 Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to Tom S., 04-05-2000 06:22:26
If it is at my Indy house very long, I will be shooting fresh paint on it so it is not such an eyesore. It will be in the front yard. Can't get it around to the back. :(
Tom S.
04-06-2000 06:54:38
 Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-05-2000 07:14:47
Out front is alright too. The only problem I ever have is that my wife is always complaining about having to park behind new stuff we bring in. I sometimes think she is one of the main people pushing for stricter county zoning ordinances!
We are standing by for Voyagee 2000 updates. Tom S.
The Red
04-06-2000 08:11:59
 Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to Tom S., 04-06-2000 06:54:38
It's ready. I am trying to contact a nearby farmer who also has an immaculate 4400 along with a 9500. He drives these roads in his equipment all the time and I really would like for him to drive it and I follow in my pickup.
Talked to my neighbor and she doesn't mind the combine being parked in my yard next to her property.
Tim W
04-03-2000 16:52:15
I swear it doesn't look like it has a windshield. Hope it doesn't rain:) Good luck Red.
The Red
04-04-2000 05:15:34
 Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to Tim W, 04-03-2000 16:52:15
Believe me Tim it does. My wallet was bare after paying for a new one!
I definitely won't be running this thing supersonic on the way home.
john d
04-03-2000 14:08:00
1) FIRE EXTINGUISER!
2) Channel 13 News Helicopter...?
3) Sign which says "Raceway Park or Bust!"
When do you plan to do this???
The Red
04-03-2000 14:20:37
 Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to john d, 04-03-2000 14:08:00
Glad you mentioned the extinguisher John. Need to pick up a new one.
Right now about any weekend with good weather. I could move it right now but the traffic is getting heavy already. I just drove the 4.2 mile route.
paul
04-03-2000 20:05:09
 Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-03-2000 14:20:37
Could I ask about the police escort???? Man, would that cost around here in Minnesota! Is this something you are required to do?
Sunday mornings always seem to be good times to move stuff, early Sunday.
--->Paul
The Red
04-04-2000 05:14:16
 Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to paul, 04-03-2000 20:05:09
Paul the escort is my idea. The grain table is 13.5 feet wide so it will be hanging well over the centerline. There are lots of mail boxes so I have to pretty much stick to the center of the street. Sunday morning would be the most ideal time in Indy. This town sleeps in on Sunday.
Dave Sayer
04-04-2000 09:10:46
 Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to The Red, 04-04-2000 05:14:16
Could you not take the header (grain table) off for the trip and fetch that on a trailer if it is only 4 miles away (this is what we do in the UK)
Good Luck!
The Red
04-04-2000 09:16:39
 Re: Re: Re: Re: Re: Re: JD 4400 Combine ready for maiden Voyage ?!?!?!?! in reply to Dave Sayer, 04-04-2000 09:10:46
Good afternoon Dave. I would do that but I don't have a trailer at my disposal.
