pic of my new holland 450 deluxe
wh
09-03-2007 11:02:42
third party image
took all the cable lift/front half hook up off and replaced it with a 2X12 hyd cylinder.
kmcampbeky
09-05-2007 07:03:55
 Re: close up of cylinder in reply to wh, 09-03-2007 11:02:42
Did you have to make the piece between the cylinder and mower and what size cylinder did you use. I've done the same thing to my 451 as the Double Hitch didn't work on my tractor. Also how well does the bar float on the ground?
John in Ct
09-03-2007 19:03:12
 Re: pic of my new holland 450 deluxe in reply to wh, 09-03-2007 11:02:42
I was wondering, how did you attach the mower to the tractor? Also, does it make the front end light, especially when going up a hill? Thanks!!
BobinKY
09-04-2007 20:42:27
 Re: pic of my new holland 450 deluxe in reply to John in Ct, 09-03-2007 19:03:12
I have basically the same size and weight sycle mower for my Allis WD and it does not make the front end light when mowing up hills. Good work on the mower. It looks slick!
wh
09-03-2007 20:57:15
now it is just a regular 3 pt hitch. really does not make the front end any lighter. just did away with the "double" hitch. have a caseih cx90 with the newfangled electronic controlled 3 pt hitch. converted it so i could hitch to it too.
wh
09-03-2007 11:04:21
third party image
another view
