Ford 515 sicklebar mower
ewotsr
09-02-2007 04:03:23
I am having a devilish time removing the knife! The manual says to remove bolt and slide the knife out, I have loosened the bolt but the washer won't let the bolt out. Is it a washer and a bolt or a one piece bolt and washer? Any help would be appreciated. Dick
murn ga
09-02-2007 08:00:35
 Re: Ford 515 sicklebar mower in reply to ewotsr, 09-02-2007 04:03:23
It is a bolt and a washer. If I recall correctly the washer is just a protective sheild for the ball brg. Try screwing the bolt back in the sickle a couple threads and putting your socket over the head of the bolt and taping down.A good penetrant would help.
ewotsr
09-16-2007 06:02:22
 Re: Ford 515 sicklebar mower in reply to murn ga, 09-02-2007 08:00:35
After much angst and toil, I finally got that bolt out to remove the knife. The bolt and washer are two pieces however the bolt was rusted to the bearing and therefore kept turning in the raceway. Lots of prying and it finally popped out. Dick
ewotsr
09-02-2007 12:02:42
Thanks, at least I know what I am working with, apparently it has been awhile since the knife was removed so the washer is really rusted. Good idea about tapping down on it. r.s.
