Banvil question..
HAYBOY
08-31-2007 20:18:06
How much does Banvil usually go for $$? I Am looking to spot spray about 4 acres mixed with 2,4-D? Any application rates would be great, spraying for milkweed on some 3rd cutting grass hay. Milkweed is about 10" tall right now
Jerry/MT
09-01-2007 10:38:00
 Re: Banvil question.. in reply to HAYBOY, 08-31-2007 20:18:06
What you are looking for is called Weedmaster or Rangestar and it's a mix of dicamba(Banvel) and 2,4-D all ready mixed. Use it per the label. You can usually look up on the web for the labeled use for the weed you are targeting.
msb
08-31-2007 20:27:05
Banvel is about twice the price of 2-4-D, depending on the formulation of the 2-4-D. Ester is a quicker kill. Amine is a slower, but surer kill. I would use a pint of 2-4-D along with a pint of Banvel at this time of year.
paul
08-31-2007 20:33:25
 Re: Banvil question.. in reply to msb, 08-31-2007 20:27:05
Sounds about right to me.
Clarity is a less volitale mix of dicomba (the killer in Banvel). It would be safer near gardens & such. Often priced the same.
Sterling is one of several generic versions of Banvel, which will be a bit cheaper. The patent went off on dicomba a couple years ago....
--->Paul
msb
08-31-2007 20:43:45
 Re: Banvel question.. in reply to paul, 08-31-2007 20:33:25
Banvel drift shouldn't be a problem at this time of year and will be the cheapest. The new Status(dicamba) would be my weapon of choice if drift were a potential problem
paul
08-31-2007 21:04:58
 Re: Banvel question.. in reply to msb, 08-31-2007 20:43:45
Drift would not be a problem 'here' this time of year either, but my sis & hubby were in Tulsa this week where it was over 90 degrees every day, near 100 several.... Might be a problem 'there'. :)
I can't keep up with all the generics any more, thanks for the name.
--->Paul
msb
09-01-2007 07:22:45
 Re: Banvel question.. in reply to paul, 08-31-2007 21:04:58
Status is a new less volotile formulation that stays put better than Banvel or even Distinct.Think it is by BASF.Agree on the keeping up, especially the generics.
