Resealing the howard rotovator
Brian
04-02-2000 19:35:45
My rotovator is leaking gear lube. Has anyone resealed one? LET ME KNOW WHAT I'M Up AGAINST.
Paul Fox
04-03-2000 03:04:54
 Re: Resealing the howard rotovator in reply to Brian, 04-02-2000 19:35:45
Depends. Where is it leaking from, the right-angle gearbox, the chain drive case or the tine shaft bearing? Chain case is an easy fix, tine shaft bearing seal is not too bad, just have to pull the ends off and pull the shaft out, pull the bearing and pop a new seal in. Never been into the gearbox, but I'd assume it'd be somewhat more of a challenge.
