How late to cut hay in Indiana
Joe in IN
08-31-2007 06:08:18
I realize this will depend on weather but....
I have always heard Sept 15th is the last time you should cut alfalfa. I usually assume some leeway is built in and push that to the 22nd.
Due to weather/life, I just took 3rd cutting on 10 acres. Cut Aug 30(last night). 28 days would be Sept 27.
I am in West Lafayette area and assuming I had a good window to cut on the 27th or 28th how dangerous is it to cut then. Alfalfa field was planted in 2004 and is a pretty solid field.....
Given the price of hay I would really like to get more but replanting a field gets expensive...
Eric SEI
08-31-2007 19:49:10
 Re: How late to cut hay in Indiana in reply to Joe in IN, 08-31-2007 06:08:18
I've cut in October, but with cool, shorter days drying can be a problem. Of course, down here near the Ohio River we also have trees bordering most hay fields which also causes problems drying.
paul
08-31-2007 09:16:07
My understanding is it is ok to cut after the first frost. Weather is the ememy then tho.....
Alfalfa goes through a cycle of storing food in the roots, & growing rapidly to make buds depleting the roots. You want to go into winter with the roots full. You shouldn't cut in that 'rapidly depleting' phase.
--->Paul
Allan In NE
08-31-2007 06:26:53
You'll want to get it off of there before the snow drifts build up. :>)
Allan
Joe in IN
08-31-2007 06:44:13
 Re: How late to cut hay in Indiana in reply to Allan In NE, 08-31-2007 06:26:53
Hey Allan...
I believe in fall of 2005 you planted some alfalfa. How did that field turn out. I planted some at the same time as you. Ithought mine was going to fail as it sat there amonth with zero rain.....
Mine came on though was a littel thin first cutting of 2006 but since has been an excellant field for me...
Allan In NE
08-31-2007 07:03:55
 Re: How late to cut hay in Indiana in reply to Joe in IN, 08-31-2007 06:44:13
Yeah,
We planted at the same time as I remember. Field just turned out great after it was all said and done.
Now, if I could just get some moisture. Still haven't got a real good cutting off of it yet. :>(
Allan
