hooking up a scoop
richtrailer
08-31-2007 05:48:45
Does anyone know how to put the 'scoop' onto a 1942 9N tractor? We bought the tractor from a man with no knowledge of how to use anything. Great shape, but, no books. I just need to be told how to put the scoop on the tractor so I can move rocks and dirt and clay on the yard. Please respond with any help. Thanks!
Pooh Bear
08-31-2007 19:13:01
 Re: hooking up a scoop in reply to richtrailer, 08-31-2007 05:48:45
I use one on my 8N and I love it. I have moved tons of dirt and rocks.
Mine uses a trip/reset lever to dump it.
I found a great way to set it up easy.
First, attach it to the tractor with the top link extended.
Raise the 3 point and dump the scoop.
Now lower the scoop back to the ground all the way.
Start adjusting the top link shortening it until the
trip lever resets itself, then a bit shorter to make sure.
Now when you dump it you can just lower the empty
scoop to the ground to automatically reset the dump lever.
If you are mounting the scoop backwards just reverse everything.
Shorten the top link to attach it, then lengthen it to adjust the trip lever.
Now using these methods also means that the mouth of the scoop
is always leaning downwards and material wants to fall out.
So another way to adjust it is to set it leaning back just a little,
but somewhere near where you will be dumping material place a brick
or some other solid object. Then you can lower the front of the scoop
on that object to reset the lever. Try it the other way first.
My dirt scoop is one of my most used implements.
Pooh Bear
HCooke
08-31-2007 12:10:06
I use a scoop with my N's. Just hook it to the three point hitch and adjust the top link to get the proper bite in the soil. I have never had a clutch problem with using one. Take it slow, use first gear, dont't overload it and be careful on slopes.
richtrailer
08-31-2007 13:21:49
 Re: hooking up a scoop in reply to HCooke, 08-31-2007 12:10:06
Thanks, we will give that a try today.
cb in wisc
08-31-2007 11:42:58
If it the kind I am thinking about, I was told to never use one as you"ll burn up your clutch.
hay
09-01-2007 08:21:49
 Re: hooking up a scoop in reply to cb in wisc, 08-31-2007 11:42:58
clutch can give out IF the scoop is used for heavy digging whereas the the rear tires are spinning to get traction. just light digging at slow speeds should be alright. i would not push an old tractor like a ford "N" series too hard or there will be clutch problems. box blade with scarfiers to break up hard soil would be better and then scoop up.
