IH plow ?
Terry C
08-30-2007 13:35:36
I recently purchased a 3 bottom plow that I belive is an IH plow. It is a trailer type with hydraulic lift. The only #s that I can find on this is on the back of the moldboards. The # is SCIH462314R1 or I the last digit is either a #1 or the letter I, I cannot tell. I am looking for any info on this plow and would love to get my hands on the owners manual for it. I have no real idea how to adjust or use this plow and I would appreciate any help that anyone can give. Thanks, TerryC
jwal10
09-02-2007 07:01:04
 Re: IH plow ? in reply to Terry C, 08-30-2007 13:35:36
I have an Operator's Manual for setting up a #60 plow and there is a picture in it that is at the same angle as the second picture and it is identical to your plow. I have a #60 plow in the 2 bottom and all the parts look the same....James
Randy S.E. MN.
09-02-2007 06:12:03
I beilieve I have that same plow, and it is a IH Model 60. Anyone please correct me if I'm wrong...Randy
digii3
09-01-2007 12:42:14
 Re: Here's Terry's Plow Pics in reply to Terry C, 08-30-2007 13:35:36
[quote="El Toro"](quoted from post at 22:20:15 08/31/07) Here are Terry's pictures, I hope. He needs help identifying the plow. Hal
This plow is identical to my plow, which I recently got. All I know about it is that the long bar at the angle ontop of this unit should have a metal rope attached to it so you can pull on it to adjust the height of the blades. This adjustment lets you set the lowest the plow can go. Setting 3 or 4 from bottom is about 8 inches I think. The unit is lifted and lowered to your setting by hydraulics obviously.
I would love to get a copy of the manual or service manual to this unit as well.
El Toro
09-01-2007 07:10:11
Hi Terry, If you haven't received any responses on your plow I would put another request on today's forum. If you can't get your pictures to post I will post them again. Hal
El Toro
08-31-2007 19:20:15
third party image
third party image
third party image
georgeky
08-30-2007 13:47:33
I don't know about the numbers, but if you post a pic, me or someone else will likely know which plow you have. There was several different model of trailing plows. The moldboard number only means it is a Super Plow Chief bottoms on the plow. They were used on most plows and could have even been added.
