Adding hydraulic oil MF 32 loader
Steve IA
08-30-2007 11:54:46
Can't locate a manual yet so will bother you with a question. How does one check the fluid level on this loader, and where is it topped off? There is a likely looking air vent on top of the loader levers. Is this a fill port? Thanks.
Steve
tg in VA
08-30-2007 18:28:14
 Re: Adding hydraulic oil MF 32 loader in reply to Steve IA, 08-30-2007 11:54:46
The dip stick is under the vent cap (on the left next to the control levers). My recollection is that you have to unbolt it, unscrewing the vent cap won't do it. Be sure to clean the area around it before unbolting. It is recessed on the front and trash accumulates that could fall in the reservoir and contaminate the hydraulic fluid.
One other thing, DRAIN the fluid BEFORE removing the filter. If you don't you will have one heck of mess on your hands (the sad voice of experience speaking!).
MASSEYMAN178
08-30-2007 12:30:56
i have a 200 massey loader and that vent cap w/hex nut under it is your fillport and should have a dipstick attached as well
