Dearborn Sickle Bar Mower
Exmarx
08-28-2007 12:27:57
Would a Dearborn sickle bar mower fit on a Ford 900? If so, how does the swathe bar attach? Thanks, Ed
Oldmax
08-29-2007 15:21:55
 Re: Dearborn Sickle Bar Mower in reply to Exmarx, 08-28-2007 12:27:57
third party image
Here is a picture of the bracket I made to go under right finder mount of 1715 Ford/New Holland for Dearborn mower. Click on link for picture of mower on tractor.
JK-NY
08-28-2007 17:36:03
What model of mower are you asking about? I think all the rear mounted models would work, not sure about the belly mower. I have a model 14-53 (similar to ford 501) which goes on a 960 just fine. It is important to have the necessary brackets that either hook to the lift arms or go under the right side of the tractor, depending on the model of mower.
Scott PA
08-28-2007 17:35:27
No, it will not fit a 900 rowcrop tractor, it was made for the 9N, 8N, NAA and 6/800 series tractors with the correct brackets which are usually left on the previous owners tractor.
steveormary
08-28-2007 12:54:06
Exmarx;
Ours would fit on an 800,a later 2000(3cyl.) and other Fords and Fergusons we had.
steveormary
Exmarx
08-28-2007 13:13:49
 Re: Dearborn Sickle Bar Mower in reply to steveormary, 08-28-2007 12:54:06
Where do you connect the kickback bar?
dakenredd
08-28-2007 14:07:35
 Re: Dearborn Sickle Bar Mower in reply to Exmarx, 08-28-2007 13:13:49
It's been a long time, but I remember a cast bracket with a socket similar to the end of a lift arm attached to the bottom of the right axel with the fender bolts. this was on an 8n. Some of those mowers also used extensions on the lift arm assemblies. David
steveormary
08-28-2007 17:08:32
 Re: Dearborn Sickle Bar Mower in reply to dakenredd, 08-28-2007 14:07:35
OK,it has been a long time. We had brackets that went on the fender bolts under the axles. These were for stabilizer bars. If we are talking the same bar(breakaway bar) it connected to the left bracket and a regular stabilizer bar to the right bracket.
It is alot easier if you have some help mounting the mower.
steveormary
