JD 290 planter
farmerweber in
08-26-2007 19:55:37
Benn looking for a set of hydraulic lift irons for a 290.No longer available from Deere & Co.Getting tired of messing with the clutch lift every spring.Can anybody give me the dimensions of them so I can fab a set?The picture in the back of the owners book isn't much to go on and the parts book only has part numbers.I broke down this spring and got a 3pth A-C and the fertilizer feed isn't working right on it.It might be easier to adapt the 290.Thanks
johns48jdb
08-27-2007 13:41:21
 Re: JD 290 planter in reply to farmerweber in PA, 08-26-2007 19:55:37
hi, we had a two row planter on a ca ac. what a mouthful. any way the drive shaft kept breaking and years later i realized that the frame was bent in an arch and causing the problem. don't know if this helps or not.
